BizHub C450 Error c-2558
  • ewengstr
    • Aug 2025
    Can anyone help me with this error?
    The customer actually dropped the K image unit and dumped toner everywhere. After cleaning up the area and reinserting the image unit, the error occurred.
    Thanks in advance
  • tech51
    • 846
    The image unit has probably lost some developer as well as the toner and will need to be replaced.
    • ewengstr
      Thanks for the quick response.
      Do think it may be possible to clean the unit and "recharge" it with toner?
      • tech51
        • 846
        Its the developer contained in the unit that has spilled, in simple terms this mixes with the toner to create the copied image. There is no way to recharge the unit with developer (as far as I know) and even if you could I think the unit would have been damaged internally by being dropped. I`m afraid to say that a replacement is your only option.
        • ewengstr
          I will recommend replacement to the customer. Thanks again for your help.
          • Morlock49
            • Mar 2009
            • 166
            replace the unit, no way to recharge it
            Sorry folks, reputation removed by Just Manuals, because he's a sad little wanker
