Bizhub 350 vs. Di3510 heat roller
  • OBXtech
    \tek-ˈni-shən\
    • Sep 2009
    • 37
    Part numbers are different, but are the rollers themselves the same? I've got a Di3510 heat roller and a customer with a bizhub350 that needs a heat roller.
    "I have not failed. I've just found 10,000 ways that won't work."
    -Thomas Alva Edison
  • mo0651
    • 1054
    The toner for the machines is different. so they made the coating for the rollers different. They don't sell the hot roller separate for the Bizhub.
    • OBXtech
      \tek-ˈni-shən\
      • Sep 2009
      • 37
      Hmmm...I see what you're saying. However, I checked with a third party supplier (Katun) and found that they sell just the heat roller for the bizhub. And it's actually the same part number as the Di3510 heat roller.
      My plan is to close this call this afternoon. Has anyone actually ever replaced the bizhub roller with the Di series roller? What was the outcome? If it wore prematurely, how premature was it? If there were disasterous effects, then I may have to look into replacing the entire fusing assembly. I'm trying to save cost (a lot of cost) by just doing the heat roller.
      -Thomas Alva Edison
      • minimerlin
        • 851
        There is no problem with using these rollers, they fit and work just the same..just go ahead and use it. They are the ones we use in both the Bizhubs and the Di`s
        Please do not PM me without asking first.
        • fixthecopier
          ALIEN OVERLORD
          • 4713
          I use the aftermarket rollers, no problems yet. The fusers will swap out if you swap the lamps.
          • Hansoon
            • Sep 2007
            • 3402
            No problems here too. We are using the Katun UFR's for the Bizhub350 without problems until now.
            Hans
            • lvangsnes
              We have used an aftermarket rebuild kit with both fusing rollers, collars, bearings, some high-heat tape for the thermistors, sponge rollers, some grease and cleaning aids. We have not had any issues with the rebuilds. We have a guy in the shop that rebuilds the cores, and the techs pick them up when needed. The kit is from Copylite and it costs about $95.
              • Hansoon
                • Sep 2007
                • 3402
                [QUOTE][The kit is from Copylite and it costs about $95./QUOTE]
                You have a part# please?
                Hans
                • lvangsnes
                  Copylite pn PMK3510
                  • Hansoon
                    • Sep 2007
                    • 3402
                    Thanks.
                    Hans
