Part numbers are different, but are the rollers themselves the same? I've got a Di3510 heat roller and a customer with a bizhub350 that needs a heat roller.
Bizhub 350 vs. Di3510 heat roller
Hmmm...I see what you're saying. However, I checked with a third party supplier (Katun) and found that they sell just the heat roller for the bizhub. And it's actually the same part number as the Di3510 heat roller.
My plan is to close this call this afternoon. Has anyone actually ever replaced the bizhub roller with the Di series roller? What was the outcome? If it wore prematurely, how premature was it? If there were disasterous effects, then I may have to look into replacing the entire fusing assembly. I'm trying to save cost (a lot of cost) by just doing the heat roller."I have not failed. I've just found 10,000 ways that won't work."-Thomas Alva EdisonComment
My plan is to close this call this afternoon. Has anyone actually ever replaced the bizhub roller with the Di series roller? What was the outcome? If it wore prematurely, how premature was it? If there were disasterous effects, then I may have to look into replacing the entire fusing assembly. I'm trying to save cost (a lot of cost) by just doing the heat roller.They are the ones we use in both the Bizhubs and the Di`s
Please do not PM me without asking first.Comment
I use the aftermarket rollers, no problems yet. The fusers will swap out if you swap the lamps.The greatest enemy of knowledge isn't ignorance, it is the illusion of knowledge. Stephen HawkingComment
lvangsnes
We have used an aftermarket rebuild kit with both fusing rollers, collars, bearings, some high-heat tape for the thermistors, sponge rollers, some grease and cleaning aids. We have not had any issues with the rebuilds. We have a guy in the shop that rebuilds the cores, and the techs pick them up when needed. The kit is from Copylite and it costs about $95.Comment
lvangsnes
