Anyone know what this code means?...
Bizhub C6500 - C-6703 Report Code
suess
I think I just had that, it was NOT a cheap fix. Check and make sure the cable is properly connected from the fiery to the copier. BE SURE TO TURN THE POWER OFF FIRST! If it messes up it usually blows a board. (I forget which I'd have to look it up)Color is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
Agree the fix to this is not cheap.
In order of expense:
Fiery to copier cable
C6500 Image processing board
Fiery video card that connects to the copier
As far as moving connections with the power on - we had a salesperson hot swap the cable for a Fiery for one on a Creo in our showroom. Blew the copier IP board, and the video cards in two controllers. Replacing them was two months salary for me but this guy gets an attaboy for selling 5 machines this month. There is no justice.Comment
