Trying my hand at rechiping the iu's, and the fuses on the fuser and belt. Anything i need to know or have to do after i replace chips and fuses?
KONICA C350
Make sure to use OEM toner on these machines. It will do no good to extend the life of the IUs if you're shortening the life at the same time by using aftermarket toner.But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
If the counter fails to reset, check to see if any P codes are present and clear those problems to allow the machine to pop the fuse or chip."Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
---Groucho Marx
Please do not PM me for questions related to Konica Minolta hardware.
I will not answer requests or questions there.
Please ask in the KM forum for the benefit of others to see the question and give their input.
Before I reset the IUs or the transfer belts, I always print out a 11X17 halftone test prints in each color. If there are any defects, I replace them. If you only have defect in one color, replace that color. If the same defect is in all colors, then replace belt.
Also, when I reset the transfer belt, I pull the transfer belt cleaner assy and vacuum it out.The family that prays together, stays together!
Smile God created you and He doesn't make mistakes!
Relax, God IS in control!
Be still and know that I am God
Ps 46:10Comment
