bizhub 350 B/W how do I reset fuser
  • chexin51
    • Aug 2008
    • 37
    I have a question concerning a bizhub 350 black/white copier that indicates the fuser is due to be changed along with the ozone filter. The fuser only has 175K copies ( should do 450K ) and if there is no wear I'd like to reset it.
    1. Can I replace a .0625 A fuse in this unit and just clear the life counter for the ozone filter ?
    2. And if yes where is this fuse located ?
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    In the counters, clear the maintenance counter. These b/w fusers do not have a fuse.
    • chexin51
      • Aug 2008
      • 37
      thanks for the reply
      Thanks for the quick reply - still learning the KonMin lineup
      • alonzo
        • 63
        I think on the wiring harness there is a green wire that hides the fuse
        • fixthecopier
          ALIEN OVERLORD
          • 4714
          no fuses in these fusers. Color machines maybe, but I do not think Konica Minolta has ever put fuses in B/W machines in the last 10 years.
