minolta di 650 49-03 code
  • digicor
    • Jul 2008
    • 1159
    anybody know what a 49-03 code is on this machine?
    all i have for it is an intravia and it aint in there...
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    I searched all my manuals, it did not show up. Maybe it is one of those codes that pop up if you copy money.
    • Kmdurrin
      Copy/Print/Network Tech
      • Dec 2008
      • 132
      SC49-01, SC49-02, or SC49-03 codes.
      Solution
      PROBABLE CAUSES:
      1. Outdated firmware.
      A flash ROM upgrade is available to correct this problem. The latest version firmware or system software is available via the Konica Minolta Download
      2. Improper shut down procedure of the controller.
      Here is the correct shutdown procedure:
      a. Shutdown the controller via theMFP control panel.
      b. Turn off the sub switch (front switch) of the printer.
      c. Turn off the main switch (rear switch) of the printer.
      This procedure assures that the controller and printer are properly synchronized when power is applied. If the sub switch (front switch) is the only switch turned off, the Service Code will be generated the next time the printer is restarted.
      We get this one pretty frequently. Just re-start the controller, and it should go away.
      Parts: Its what your copier craves!
      • digicor
        • Jul 2008
        • 1159
        its a print controller code
        ive a problem ,,, the print controller just keeps resetting it self
        "please wait" then back to "server booting" then please wait
        how do i break the cycle and restart the whole thing... i cant get to the screen in the fire e to shut it down??
        • buster68
          • Nov 2008
          • 181
          the Fiery has crashed. You'll need to reload the Fiery system software. If the Fiery was purchased with the harddrive option, you may need to get a new harddrive and load the system software onto the new harddrive.
          • digicor
            • Jul 2008
            • 1159
            ok thanks i was afraid this was the issue
            • alexfixes
              • 68
              update teh firmware. need help let me know and i will send you the procedure.
              DESCRIPTION:
              SC49-01, SC49-02, or SC49-03 codes. SOLUTION ID:
              4,003,706
              SOLUTION:
              PROBABLE CAUSES:
              Notes:
              a. See bulletin [[3481A| URL http://techweb.konicabt.com/tpm/mfiles/3481a.pdf]] for details on
              this issue.
              b. Make sure that the current version of system software (with applicable patches) is installed on
              the controller.
              a. Shutdown the controller via the Di650 control panel.
              USAGE:
              1
              DESCRIPTION:
              Last edited by alexfixes; 01-18-2010, 11:28 PM. Reason: more information i have for this user.
              • digicor
                • Jul 2008
                • 1159
                thsnk you for the info
                could u send me the firmware and the instructions,
                thank you again.
                service@copierprinter.com
