konica 7085 VIF :confused:
  • wwandrei
    • 40
    Hello. I wonder if anyone can help me with a PART NUMBER for video interface card from konica 7085 or DI 850 ... i can`t find it anywere and i have some copiers that has this card broken. (the VIF card is the card from the copier that makes connection between copier and print controller IP602-7085; pi8500-di850). Thank you !
  • Albonline
    • Sep 2008
    • 1144
    IP602/7085 VIF board (p/n 13TL-7311).
    • Stirton.M
      All things Konica Minolta
      • Oct 2009
      • 1804
      Those little cards are a pain in the ass. You look at them crosseyed and the damn things fail. I've lost count of how many I've had to replace over the years.
      "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
      ---Groucho Marx
      Please do not PM me for questions related to Konica Minolta hardware.
      I will not answer requests or questions there.
      Please ask in the KM forum for the benefit of others to see the question and give their input.
      • wwandrei
        • 40
        Thank you for your replay but i don`t know if this is the Part Number. If you try to google it you can`t find anything about it ... and I have one right in front of me and the Part No written on it is: 13TM-901(2) ... a Part No should be the same for same component ... the Serial No is different. So .... ? And yes those cards are so weak ... I already have 3 broken cards and for konica 7075 (ip601) i lost the count too ...
        • Stirton.M
          • Oct 2009
          • 1804
          I've looked through the various parts manuals and even through the TSBs....
          What I found was the same as what Albonline found
          TSB TAUS0702173EN00
          Products:
          IP-602
          IP-602M
          7085 Options:
          None Specified
          Details
          Subject:
          Does the complete VIF kit have to be ordered to get the VIF board?
          Description:
          Part number for the VIF board.
          Solution:
          The VIF board can be ordered individually. IP602/7085 VIF board (p/n 13TL-7311).
          ---Groucho Marx
          • wwandrei
            • 40
            Ok. Thank you guys. I more little question : di 850 VIF is the same as on 7085? It seems this is the PN. Any suggestions where I can buy this card? Preferable in Europe, and not from konica minolta `cause their price is "untouchable"
            • Stirton.M
              • Oct 2009
              • 1804
              more than likely.
              I cannot find other reference to this unfortunately.
              ---Groucho Marx
              • mrwho
                Major Asshole!
                • 4299
                Probably the VIF is the same. BUT you'll probably have to flash the VIF with the Minolta firmware so it will work.
                I say this because I once (a long long time ago) had to install a Minolta controller on a Konica machine (well, actually I had to do it twice, once it was a Minolta Controller on a Konica 7165 and later it was a Minolta controller on a Konica 7075) and it only worked after I flashed the Konica machines with the Minolta firmware.
                So, and since I'm almost sure the VIF has its own firmware, you'll probably have some flashing to do.
                Mascan42
                Ibid
                • wwandrei
                  • 40
                  7075 vif is tha same as di 750 vif i`ve made the test ... no fw needed, but i don`t have a di 850 copier to test that too ... but i assume is the same.
