minolta di 550 service manual
  • zacabbey
    #16
    let me know your email address.
    will send file thru
    • agentx
      #17
      you can send it to me at the charity:
      partners@partners-international.org.
      I held off on installing pagescope... when it got to making SQL databases I quickly got out of my league :-)
      Thanks for the help.
      • RRodgers
        • Jun 2009
        • 1947
        #18
        Pagescope what? were you installing?
        • agentx
          #19
          PageScope Light. I thought I needed it to configure the printer/scanner on the copier.
          • RRodgers
            • Jun 2009
            • 1947
            #20
            Ya usually can just do it from right there in admin mode.
            Utility, admin, network settings. Once you get an IP into it, you can just plug it into your network and then fire up your browser. (I prefer Firefox IE can be problematic) and then do all your settings from there. (you'll need to log into admin more on the machine in your browser)
            HTH
            • agentx
              #21
              Thanks for the pointers. I must be missing something or my machine is not set up that way. I cannot find anything for an IP setting in the admin mode unless I am completely missing something. Here is what I've tried:
              Utility>Administrator Mode
              The only options I get are:
              Copytrack
              Copy Track Data
              Max Copy Sets
              Disable Sleep
              I tried going into the service mode (I think) using something I found in the manual
              utility>meter count> [stop - 0 - 0 - stop - 0 - 1 ]
              That gets me into another admin mode, but the closet thing to an IP is "I/O" but that only shows me stuff on feeder trays, etc.
              I went through all those menus and can't find anything about setting the IP.
              What am I missing....? :-(
              • agentx
                #22
                Also, I got adventurous today and opened it then used the jumpers to set it back to the Factory default. Still nothing. The green light on the card lights and stays on when the network cable is installed but the other light does not flash and I still cannot get the computer to see it. I connected to the internet from a laptop connected to the ethernet cable so I know that works.
