C2701 bizhub 420
  • aleksander
    • 378
    C2701 bizhub 420
    Error with my bizhub 420 again
    Error code C-2701 related with charging abnormality. Based on Service manual, estimated abnormal part is Charging Corona, HV and PRCB. I replaced the Charging corona, then checking the HV and PRCB is fine Then I do trouble reset. No C-2701 appear. But, next day the evil code is appear again.
    I don't know what's going on with my bizhub 420.
    Any solution? Thank you for sharing solution.
  • Kmdurrin
    Copy/Print/Network Tech
    • Dec 2008
    • 132
    Description
    C-2701 is displayed at power on.The suggestions in the Service Manual have not resolved the problem.
    Solution
    CAUSE:If the components cited in the Service Manual (Charging corona, High voltage unit, and Printer control board) have not resolved the problem the cause could be poor contact with the drum unit.
    SOLUTION:Check drum unit contacts and clean if necessary.
    Hope this helps
    Parts: Its what your copier craves!
    • aleksander
      • 378
      Originally posted by Kmdurrin
      Description
      Solution
      Hope this helps
      Thank you for your advise.
