BIZHUB C220
  • thuo
    • 155
    BIZHUB C220
    quite a new machine.powering on but hangs on the hour glass .tried to swap the control pannel , the memory, disconnected the hard disk but the problem is still recurring
    any assistance please.
    thanks.
  • copytechman
    • Nov 2008
    • 954
    Does the engine fire up (as if it's gonna come alive?), although its not quite the same, i've seen the c353 series do something like this and for me it happened both ways.. 1st way was a mfp board went, second was an nvram chip got corrupted/went.. so I guess it could be similar! I'd try to get the fire up with a known good nvram/ and/or mfp board (but only change out one @ a time).
    Regards!
    A.
    • thuo
      • 155
      know what machine fired up to ready state made a test print then machine reverted back to hanging state after switching on and off
      • Stirton.M
        All things Konica Minolta
        • Oct 2009
        • 1804
        Check all the connections, memory cards, nvram plugged, ribbon cables, VIF cable and so on.
        "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
        ---Groucho Marx
        Please do not PM me for questions related to Konica Minolta hardware.
        I will not answer requests or questions there.
        Please ask in the KM forum for the benefit of others to see the question and give their input.
        • tech51
          • 846
          These machines are so flaky. Had any jamming issues yet? You will sooner or later (J11-44). On to your problem I would update the firmware to the latest (81 bug fixes in the last EU release) Also pay attention to the firmware readme about removing the network cable, if fiited, before booting up after update. I had one hang like this because the customers network had crashed. Removing the network cable and rebooting fixed that one. Hope this helps...
          • RRodgers
            • Jun 2009
            • 1947
            I'd recommend flashing it first before ya swap anymore stuff.
