DI 3510F print with lines
+ More Options
Posts
  • n3o
    • 38
    DI 3510F print and copies with lines , i thought it's the IU, but first (50-70 pg) copies/prints are clean and after that they appear with lines, it's the IU or something else ? if i open the fuser/duplex door and wait for it to chill, 50-70 or so copies are normal .....
  • KEVIN900
    Copier Ninja
    • Oct 2009
    • 200
    You already troubleshot it n3o. Replace the fuser unit.
    Kevin900
    • n3o
      • 38
      it's not from the fuser, because i've opened the door when printing , and the line's it's there before the paper enters the fuser , it's like excessive toner doesen't clean after one job to another this happend only on a tight line and i don't know what's the relation between this and warming up , is this some kind of symptom of IU on the way to leave me ?
      • connecticcut
        • Feb 2010
        • 53
        what is ATDC value? 155?
        • aleksander
          • 378
          did you try to change the IU? Maybe the cleaning blade.
          • connecticcut
            • Feb 2010
            • 53
            if i have problem with blade...i shall see problem after 4 or 5 copies.You have lines but do you have a white dirty on the copy?If yes,the ATDC value is not good and you have too many toner in the developper unit.
            • n3o
              • 38
              atdc is set to 160 ?!?
              • n3o
                • 38
                is it set to high ? how it's normal ? 150 ?
                • montana
                  • Aug 2008
                  • 392
                  hi.....did you check the anti spill toner blade if it is deformed or damaged? i suspect the IU too
                  good luck my dear...
                  • n3o
                    • 38
                    i've set it to 150 and did a f8 calibration still the same thing, i've also checked the anti spiil toner blade seems normal ...to me
                    • deep
                      • Jun 2008
                      • 208
                      The cleaning blade may be defective, replace it.
                      Kenny
                      • n3o
                        • 38
                        it's ok now, i think it was the atdc set to high, after doing some copies (~100) the lines dissapered
