Konica 7022 f35-4 error
  • HUNG99
    • May 2025
    Urgent! Pls help me with Konica 7022 f35-4 error code! Thank a lot!!!!! It does not work for a long time !!!
  • bushy
    • 34
    7022 f35-4
    call a tech!!!!
    you have a heater problem that needs to be safety checked
    • HUNG99
      konica 7022 f35-4
      I have called a tech, but he does not know much about 7022
      Pls show me how to settle it ! Very urgent!
      • bushy
        • 34
        f34
        go to 25 mode select software switch
        go to address 3-1 turn switch to 0
        turn m/c off/on
        a tech will understand these instructions even if you dont
        call a tech!!!!
        • ebm
          • Apr 2007
          • 183
          If you are not going to call in a qualified service tech the easiest thing would be to replace the fuser unit. If it is not the fuser unit then the problem would most likely be out of your hands to resolve without qualified technical service. The image control and printer control boards may be the next likely suspects, which would require replacement and firmware reprogramming.
          • HUNG99
            konica 7022 f35-4
            Thank you for your help! I 've solved the problem.
