I am showing a Code 2402. I have already replace the elimination lamp and the printer control board as the manual suggests. I was thinking High Voltage board but was looking for opinions. Thanks in advance.
Bizhub 500
check the small connector between drum charge corona (in fact erase lamp) and drum unit (2 wire white and red). -
badbusa
I have checked for erase lamp all the way back to connector that connects to PRCB. I have continuity. I made sure all connectors are secure on the drum unit and at the PRCB. No bent pins.Comment
