Fiery ic-408 2.0
  • jemsovic
    • Jun 2008
    • 48
    Fiery ic-408 2.0
    Please help I have problem when I install software 2.0 every print gets dump with error no supported finisher installed. but with 1.1 software I don't have any problems printing. Thanks in advance.
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    Stick with 1.1 if it ain't broke why fix it?
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • jemsovic
      • Jun 2008
      • 48
      Just wondered if there was some fixes or improvements in software, and would be nice to find release notes for 1.1a and 2.0 to see what if any are made.
      • pepper38_cnd
        • Aug 2005
        • 1075
        Here are the IC408 V2 Realease Notes
        • jemsovic
          • Jun 2008
          • 48
          Thank's, but it has nothing about new features or fixies in this pdf.
          • Albonline
            • Sep 2008
            • 1153
            ver 2.0 supports vista x64 and changes driver interface . but the message that the finisher is incorrect? what finisher are you try ing to use? if the ru unit is attached the ic 408 constantly reboots.
            • jemsovic
              • Jun 2008
              • 48
              The finisher is fu-607, and I use windows 7 x64 with almost no problems on 1.1 version. Thank's for your replays at this matter.
              • Albonline
                • Sep 2008
                • 1153
                theonly thing i can think that would do this is the wrong/bad system code load. maybe the incorrect driver?
                • jemsovic
                  • Jun 2008
                  • 48
                  I downloaded it from km.eu ftp site from ic-408 folder and name is corect, I don't know what else could be. I am now on 1.1a version and working fine.
                  • billak
                    • Mar 2010
                    • 5
                    try to update firmware to latest 60.
                    • jemsovic
                      • Jun 2008
                      • 48
                      My service man already installed latest hi sad but i am not sure if it is 60 i will check
