Konica Minolta Bizhub C450 yellow toner
  • hooman
    Our yellow toner isn't functioning properly. It properly prints the outline of the image, but the inside of it is very faint or not yellow at all. This is only happening with the yellow color, not either of the others (or with the black). This is true for images that we want to be yellow, or other colors that utilize yellow. For example, when trying to print green, only the blue is appearing. Any suggestions? Thank you!
  • kmcopier
    PSP
    • Oct 2008
    • 183
    imaging unit!!
    • RRodgers
      • Jun 2009
      • 1947
      Originally posted by kmcopier
      imaging unit!!
      Yeah pretty much. Ya might get away with a force add toner (if you know how to get into tech mode) and that "might" fix it. But usually you'll have to replace the imaging unit.
      • mo0651
        • 1054
        Clean the l.e.d.s first. see if anything changes. Just may have toner dusting.
        • barratec
          • Jun 2008
          • 162
          I had several problems like this with bizhub color series. For me the problem is the Image Unit has to be changed.
