biz hub 920 sc90xx
  • texchar555
    Senior Production Tech
    • Mar 2007
    • 142
    biz hub 920 sc90xx
    customer called about sc34-4. tech went out and reset service swith 3 back to normal state. turned off the machine and now its comming up with sc90-1 loose connection between adubd and printer board. looked up tech bullitens and found one stating about 2 wire harnesses that could be shorting out. they were not.
  • Bizhub
    • 147
    Have you got any blown ICP'S on the ADU board ?
    If I find out more I will let you know
    Regards
    • texchar555
      • Mar 2007
      • 142
      no, I sure havent. I replaced the adu board and fuser just to make sure and that didnt work. So I reinstalled the original parts and to my amazement it works. I think its an electrical problem with the site. We sent it back and it popped up with a new code. Now it says drum drive error. Im glad I got someone to talk too now. Im the only one that works with the 920 and 1050.
