Konica 7145 code F26-4?
  • copyaction
    • Oct 2007
    • 991
    Customer called with a code F26-4, I haven't gone out to see it yet and all I can find in search is F26-3.
    Is there in fact a F26-4 code and what does it relate to?
    thanks
  • copytechman
    • Nov 2008
    • 947
    Here ya go:
    F26-4 Toner density abnormality
    If L detection power exceeds
    2.6V prior to toner out detection
    by the TLD (Toner level sensor),
    the automatic toner supply feature
    should restore the toner density.
    This error occurs if this
    feature fails to restore the density.
    Toner supply unit
    Load the toner bottle again
    Regards!
    A.
    • copyaction
      • Oct 2007
      • 991
      thank you very much
