FTP scan in the shared network storage?
  • sprawl
    • Jul 2009
    • 27
    Hi,
    Is it possible to use example C280 "Scan to FTP" in the Buffalo linkstation?
    I try to allow any traffic in buffalo admin panel and set ftp settings in the copymachine:
    "Host": 191.167.1.98
    "target": disk1\shared
    "port": 21
    "admin" "password"
    C280 always tell about "no specified folder".
    If i try in the firefox url ftp://adminassword@191.167.1.98/disk1/shared" it is correct.
    So, is this even possible to scan buffalo?
    [Completed] Outaward, [Completed sertifications] C652,C552,C360,C280,C220,C35,C353,C203,C20p,C25
  • B0265
    • Jan 2007
    • 718
    I'm not familair with the Buffalo Linkstation, but if it is acting as a ftp server and ftp root folder is "shared" it should work to type only "\" as the file path on the copier.
    • mascan42
      • Oct 2008
      • 484
      The FTP scan automatically defaults to the FTP root folder. You only need to enter any subfolders that you want to scan to. Other than that, a "/" or a "." will do to scan just to the root folder.
      • sprawl
        • Jul 2009
        • 27
        if i use "\" or "." -> always says "no specified folder".
        edit:
        I dont know 100% sure if all settings is right in the buffalo(linkstation live LS-CH500L).
        There is allowed all users in all folders, and "FTP" is selected each folder.
