Minolta Bizhub C350 - error code
  • jhanks
    • Jul 2025
    Anyone know what error code c-12c0 is - just started showing up and can't seem to figure out what happened...
    Thanks in advance
    Jason
  • knightfall
    • Jul 2006
    • 633
    C12C0 Hard disk recognition error
    Unable to communicate between the hard disk and MFP Control Board (PWB-MFP).
    Get your facts first, and then you can distort them as much as you please.
    • nightshade
      Chromographic Supremesist
      • 158
      Replace the HD with a generic one for a Laptop.
      • jhanks
        thanks
        Thanks for the help - does there need to be any software loaded on the HD? or just a pre-formatted hd for a laptop?
        I am not a technician - but have computer skills
        • nightshade
          • 158
          Fresh out of the box, then you need to format it through the copier.
          • Bizhub
            • 147
            We find that enhanced IDE drives don't work ! Has anyone else had that problem ?
            We are using Toshiba 40gb drives, let me know what you are using.
            Regards
            • nightshade
              • 158
              Regards
              Never looked, I plug a part # into my computer and a couple days later I get a 40gig.
              Maybe this is the answer to why the last 2 I tried in a 8031 didn't work????
              • Scott_Lewis
                • Mar 2007
                • 519
                Regards
                I've tried this in the past with dismal results. I think it was on an embedded fiery controller....... Found the original drive had a password protected configuration profile. Finally gave up and purchased the 10x overpriced OEM drive.
