Konica /Minolta c960 error code
  • caveboy
    I just move a bizhib c350 from one location to another. Now, I am getting an error code c960 during power up and the copier doesn't work any more. Could anyone tell me what this error code means
  • trublu
    C0960
    C0960
    Bypass lifting motion failure
    standby position was started
    • mo0651
      • 1054
      This code is usually caused by the white plastic spring clutch in the bypass unit. Sometime adjust the slot where the spring clips into will take care of it.
