I'm recieving a " replace transfer unit" for my konica buzhub c352 copier. Is this the belt unit? Like this one Konica Minolta Genuine OEM 9J06R70400 Transfer Belt - eBay (item 380209687136 end time Mar-25-10 15:22:13 PDT) Are there any procedures I need to perform after I replace this unit in order to reset the system? Thank you in advance for your help.
Konica Bizhub C352 "Replace Transfer Unit" Help
Tags: 0209, 400, 8020, belt, bizhub, bizhub c35, bizhub c352, c35, c352, concern, copier, genuine, image quality, konica, konica bizhub c352, konica minolta, konicaminolta, minolta, oem, replace, reset, size, sys, system, time, toner, transfer, transfer unit, unit
The transfer belt has a small glass fuse that resets the counter. When you install the transfer belt, this fuse expires, and resets the counter for the belt. You could replace the fuse, info on this is all over the KonicaMinolta area. You install it, the machine cycles for a bit, then you're good to go. No other action is needed by the technician.Kevin900 -
Are you saying that I could replace just the fuse and it may work for a period of time. Or are you saying that I need to replace both? Thanks, CreighComment
True. It all depends on your needs and expectations quality-wise. If you're doing office work where image quality is not a main concern, then you can keep on replacing the belt's glass fuse as long as it works without any major problems. As Kevin said, they tipically last twice as rated by the manufacturer, but if you're not picky, you can make them last even longer.' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation!Comment
