bz 500
  • hussain
    • 28
    bz 500
    Hi Friends,
    Please share your ideas about this matter.
    Problem : very weak image transfer on the paper.
    Good image is producing on the drum. but transfer to paper is very weak. I cleaned all the contacts and image transfer corona unit and the high voltage board also. but still the problem exist.
    Please give me your suggestion about this matter.
    Hussain/Maldives
  • connecticcut
    • Feb 2010
    • 53
    i know maldives isles
    maybe take off corona transfert and reinstall after (some time i have this problem; first try air canet on the corona and after take off and reinstall)...i don't like this modele (many problems)
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      The wires could be bad or the post has corrosion. Swap the unit out with one from a working machine to tell
      • Hansoon
        • Sep 2007
        • 3389
        First thing coming up in my mind is paper and/or humidity but I'm sure you checked that already...
        Hans
        • salmoz
          • Jul 2009
          • 30
          Check if the sensor TCR is properly working
          • JustManuals
            • Jan 2006
            • 9838
            This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
            Paul@justmanuals.com
            • hussain
              • 28
              I replaced corona unit and high voltage board also
              but no result
              • hussain
                • 28
                Yes thats what I thought first.
                But it is not the problem. I replaced transfer corona unit also. but no result
                ahmed
                • hussain
                  • 28
                  Salmoz,
                  a good image reproduce on the drum. I want to transfer that image on the paper.
                  problem is the image not transferring on the paper
                  • hussain
                    • 28
                    Salmoz,
                    • hussain
                      • 28
                      I replaced the whole corona unit. but no result
                      • Gerg?
                        • Jul 2008
                        • 67
                        I had the same trouble on C451. Fine image on tr. belt but poor quality in the paper. I changed everything ..... finally the parameter board (EEPROM board) was the guilty.
                        • Gerg?
                          • Jul 2008
                          • 67
                          50ga -911 1 parameter memory board assy
                          • salmoz
                            • Jul 2009
                            • 30
                            mY PROBLEM WITH THIS MACHINE STARTED AND IS NOT YET FIXED WITH A PROBLEM SIMILAR TO YOURS. aFTER SOMETIME STARTED A LOT OF ERRORS C-2803 AND THERE I DISCOVERED THAT A TCR SENSOR ( THE SENSOR YOU FIND IN TO THHE DEVELOPER UNIT) WAS DAMAGED. i`M STILL WAITING A NEW ONE TO SEE THAT SOLVE ALL THE PROBLEMS.
                            • Gerg?
                              • Jul 2008
                              • 67
                              In case of bad TCR senzor there is no good image on the drum.
