Old CS Pro EP 4000
  • RRodgers
    • Jun 2009
    • 1947
    Old CS Pro EP 4000
    How do I clear the tray error codes? I have codes for tray 1-3 Also a C0914. (tray 2 lift error) I can't seem to clear them. Hitting the trouble reset button under the cover that is on the inside of the door does not clear them or reset them. I've been in tech mode (stop 0, 0 stop 1) (stop 0,0 stop 0 1 ) didn't work.
    Thoughts?
  • KonMan
    • Mar 2010
    • 15
    I'm not sure about the 4000, but the older Minolta machines had a reset button. It may be located on a small panel in the front of the machine , or on the main PWB.
    • Luther
      • May 2006
      • 682
      When the code is displayed open and close the front door if the code isn't displayed and you have the little wrench touch the wrench display the code and open and close the front door.......good luck
      • RRodgers
        • Jun 2009
        • 1947
        I'll give that a shot Luther. One thing, tray 2 has a broken gear. Anyone have a parts man for this box? I don't see it listed on Konica's web site anymore. Although the all active solutions for it is still listed.
        • Cantechman
          • Nov 2008
          • 228
          Is it the white gear with teeth on each side and a nothing in the middle? I believe its 16/40T or something like that.
          • RRodgers
            • Jun 2009
            • 1947
            Yeah, that might be it.
            • Cantechman
              • Nov 2008
              • 228
              That particular gear is part # 4425-3212-01 gear 16/40T
              • RRodgers
                • Jun 2009
                • 1947
                I'll take a pic of it with my phone and post it. I"m pretty sure we are talking about the same gear though.
                • RRodgers
                  • Jun 2009
                  • 1947
                  Ok here is a shot (a very crappy one at that) of the gear I am refering too. Is this it?
                  • RRodgers
                    • Jun 2009
                    • 1947
                    Yeah that did it. Thanks!
                    • Luther
                      • May 2006
                      • 682
                      go to precisionroller.com they have all the gears for that box and pictures of them...........good luck again
                      • RRodgers
                        • Jun 2009
                        • 1947
                        Thanks man... looks like KM still might have them as well. So we are going that route.
                        • aleksander
                          • 378
                          try Stop, 0, Stop, 1.
                          Open & close front door
