problem in the machine BH- 250
  • abbas saeed
    • Mar 2010
    • 31
    I am a new member with you
    I have a problem in the machine BH- 250
    Machine re-operation without the work of
    The message also appears to me
    See picture
    Please help
  • jotunn
    • 607
    PROBABLE CAUSES:
    1. Failed fax board interfering with operation of MFBS.
    Replace fax board kit, FK-503 (Item #4551613).
    2. There is a TCP/IP address conflict between the MFP and another device on the network.
    Remove the Ethernet cable from the MFP and PING the TCP/IP address. If the PING succeeds, speak with the Network Administrator and resolve the TCP/IP address conflict.
    • abbas saeed
      • Mar 2010
      • 31
      I will try to work the steps
      • brent
        • Nov 2008
        • 1212
        before I would order and replace a fax board kit I would initialize the machine. have you tried this>?
        brent
        • abbas saeed
          • Mar 2010
          • 31
          I tried to put a new programming
          But to no avail
          Someone told me I need to change the Main Board
          I do not know what is the solution
          The problem did not go
          The machine is not connected to NetWork
          Does anyone has a solution?
          Please
          • ck1
            • 485
            why mean 'I tried to put a new programming' firmware ? did you unset fax kit and try or down the new firmware ? if still problem you must change the MFB board.
            • tech51
              • 846
              Could either be mfbs board or NVram. I would try parts from a known good machine if possible...
              • pepper38_cnd
                Field Service Manager
                • Aug 2005
                • 1075
                Did you do a Trouble Reset using the warm reset button?
                Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
                Now into Ip TV KODI Boxes
                • aleksander
                  • 378
                  It's a bit difficult to solve this problem. First, try to rewrite the firmware. Then check the PWB-A. Then check the PC drum, is it damage on the edge. I've ever face this your problem Abbas Saeed. I check my bizhub 250 and I found the PC drum damage on the right. After replacing the drum, my bizhub 250 running well.
                  • abbas saeed
                    • Mar 2010
                    • 31
                    Thank you all
                    Finally I know where the problem
                    The MFB board by the problem
                    • brent
                      • Nov 2008
                      • 1212
                      did you have a used mfb board that you swapped out? if you look at replacing that board from minolta with a new bo ard. outchhhh
                      glad you got it..
                      brent
                      • abbas saeed
                        • Mar 2010
                        • 31
                        i did not get it , but i removed it from the machine , and i checked it in anther machine with the same modle , the same problem occur
                        now, i am ordering it from factory.
                        • brent
                          • Nov 2008
                          • 1212
                          I just looked up the mfbs board on the konica minolta website. seems they are backordered till may 12th. pn 4551 2038 01 the cost is 1638.36
                          that is a lot of coin.
                          can I ask a quick question? what is your marketing area? would a board from the us actually work in a machine from over there? I have always wondered that.
                          • abbas saeed
                            • Mar 2010
                            • 31
                            I work for a company in my country Bahrain
                            Is authorized by the Konica Minolta in the region for the sale of machinery and spare parts and toner
                            I got this problem , now the company order to board the request and pay the cost
                            Known to be expensive
                            892.865 EUR
