BIZHUB C451
  • thuo
    • 155
    BIZHUB C451
    Hi
    i have a bizhub c451 which is warming up properly until it gets to ready mode.but i cant copy, print or scan.the start key keeps on blinking red.any clue
    thanks
  • RRodgers
    • Jun 2009
    • 1947
    Hmmm.....
    Turn it off.... (both switches) then turn it back on, but while doing so hold down the utility key. When trouble reset shows up on the screen hit that. Then reboot.
    Let us know.
    • Albonline
      • Sep 2008
      • 1148
      saw this once when tech hooked up a card reader while on. had blown icp on slide interface board.
      • thuo
        • 155
        I have tried that several times but to no avail.
        • MR CLEAN OC
          will the machine allow you to re flash it, also can you get into tech rep made and check sensors, run test on doc feeder or finisher?
          • thuo
            • 155
            Can get into tech mode but cannt run any test
            • MR CLEAN OC
              try to re flash here are some other known problembs
              The Start key is flashing amber and the machine will not go to the ready state.
              Solution
              PROBABLE CAUSES:
              1. The PWB-REDB (Scanner Relay Board) has failed.
              Replace the Scanner Relay Board (p/n A00J H00A 02).
              Note : This board is also referred to as the PWB-IF board or the REYB/SCAN board.
              2. The PWB-MFPB has failed.
              Replace the PWB-MFPB (p/n A00J H020 07).
              The blue and orange scanner lights are illuminated and the START key is solid amber. The machine may have been subjected to a power surge.
              CAUSE: Failure of MFP board and NVRAM.
              SOLUTION: Replace the MFB board and NVRAM.
              bizhub C451 PWB-MFPB (p/n A00J H020 07)
              • Albonline
                • Sep 2008
                • 1148
                didyou check theses icps?
