Receiving error c2814 and c2454 on c6500
  • copies
    • Feb 2010
    • 19
    I was receiving error c2814 error. So I swaped the black drum with the yellow drum and now I receiving error c2454. I swaped the drums back and still getting the error c2454. Any ideas?
  • anothertech
    • 1771
    Sounds like a bad black toner density sensor in the black dev unit.
    • copies
      • Feb 2010
      • 19
      Thank you for your help.I will replace the black dev.
      • ESA
        Did you run a Auto Gamma Adjustment? Values on the drum swaps won't match internal values. Make sure you blow clean the drum potential sensor behind the drums when you replace or remove.
