C6500 Firmware
  • ESA
    • Jun 2025
    C6500 Firmware
    Hi I just purchased a SD-501 for a C6500. Problem is that it came loaded with the 1050 firmware. I have addressed the dipswitches all ready and the mainframe is loaded with V50. It is an Ikon CPP650 with RU-504 and LS-501 in front of it. Can anyone direct or share with me the proper firmware for this accessory. KM only has mainframe v30 on it website only. I have entered the serial into the mainframe. Bottom line the unit is not showing up and if it is connected the LS-501 and RU-504 stop working. Thanks
  • kmcopier
    PSP
    • Oct 2008
    • 183
    check your PM
    • Avalon
      RIkon Boy
      • Jun 2008
      • 53
      PM me and I'll send you the latest firmware for this,
      Mark.
      • ESA
        I now have the most current firmware, however I am trying to install via the usb service port on the copier and continue to get unrecognized media. It's formated FAT32 and as well all the directories are per service manual. What am I missing here? I have tried a 256MB and a 2GB flash drive.
        • sbillis
          • Nov 2008
          • 95
          you must change hardware dipsw and disconect-or connect a CN.
          depends from S/N of SD
          • Avalon
            RIkon Boy
            • Jun 2008
            • 53
            I use an old usb1 128MB stick and haven't had a problem, but I do remember being told that they can be quite fussy. You could always try using the ISW tool and a usb cable
            • seniortech
              • Dec 2007
              • 180
              1Gig Kingston Datatraveller, works a treat everytime
              • ni311
                • May 2008
                • 658
                ISW Trans never fails. It a little more complicated but it worth the effort. On Pro 1050, ISW is the only option, but on C6500 you should good results with USB stick, check the root folder that contains the firmware to be named properly.
                Konica Minolta Error Codes - Explanations and Solutions
                • ESA
                  Ok so I pick up a new trusted 1Gb usb and sure enough we have recognition. However.... when I run the update I get a 102 error, which is USB hardware error according to manual. Is this just one f-ing picky machine? I am still looking into the SD-501 not being recognized still. Dip switch is correct according to manual at 1 on and 2,3 and 4 off for C6500. I have hooked directly to RU-504 to. Any thoughts....
                  • Albonline
                    • Sep 2008
                    • 1144
                    try starting the unit while holding the utility key down.
                    • sbillis
                      • Nov 2008
                      • 95
                      must checj a CN.
                      there is a connector (jumper) attached in a clamp.
                      if you cannot find wich one is tell me to find it for you.
                      • ESA
                        It just above cn19. I read that was for flashing 1050 only. Do I connect cn19 jumper and leave dips as is 1 off 2,3,4 on?
                        • sbillis
                          • Nov 2008
                          • 95
                          check your PM
                          tell us the complete configuration of your system please and the initials from S/N from each peripheral.
                          • ESA
                            Config is as follows from right to left: PF-601, mainframe A03UP10000239 (fw v60), RU-504 A04KWY1000247 (fw v40), LS-501 15AU00056 (fw v20) and final SD-501 15AP00120 (fw ??).
                            • dljorg
                              • Sep 2009
                              • 93
                              There is a SN thing with SD units and the 1050 / C6500. Sounds like your attempts with firmware are right but you may need a new main board for the SD unit to make it compatible with the color machine. Sorry I do not have any more information as my company only deals with the color box. Have seen this before from a dealer in our network.
