Bizhub C550 Splotchy Image quality
  • jaymz61
    please help me with this LOW print quality on C550, u can see splotchy print result on attached file. I've changed Imaging Unit and Fusing Unit but nothing solved. should i change the Transfer Belt ?!
    I've attached the print sample... please see the file
  • ineo+6501
    • Mar 2010
    • 262
    Hi
    I had a similar fault on a C550 a few weeks ago, it was the Transfer Belt.
    The belt in my C550 had been re-fused and had run almost a full cycle again so couldn't complain.
    Regards
    • mo0651
      • 1054
      Give a little more info and we can help with more specific ideas! We can list a whole bunch of things. What is the life counter of the belt? What kind of paper? It looks like transfer. Stop the machine with the paper half in fuser and half before. What is the result? Set your thickness up to a higher setting and check result.
