Konica Minolta C6500 Quality Issue
  • cornswaggled
    • Aug 2025
    Hey guys,
    I have a rather odd issue with a streak in only some of my prints. About every two I get a dark streak. I have removed and cleaned the transfer cleaning blade, only cleared it up for maybe 150 prints. It appears in both b/w and color prints. Can someone please help? We have alot of copying to do!
    THANKS!
  • RRodgers
    • Jun 2009
    • 1947
    I've had to just replace the transfer belt cleaning blade once to stop a machine from doing streaks like that. Also be sure that the cleaning station for the t-belt isn't backing up.
    • davenzx
      Originally posted by cornswaggled
      Hey guys,
      THANKS!
      i think you have to clean all the rollers inside transfer belt. if the image still appear try to replace transfer belt.
      • ni311
        • May 2008
        • 658
        What is the counter of the machine? It looks like a cleaning blade issue.
        Konica Minolta Error Codes - Explanations and Solutions
        • cornswaggled
          I have diagnosed it as a cleaning blade and transfer belt. The issue is this belt only has maybe 100,000 (MAYBE) copies on it...
          • ni311
            • May 2008
            • 658
            Check the life counters on it. Usually if your jobs are with just a few pages and with big gaps between it is possible that the consumables to reach 100% of their lifes even if the total counter show you 100k which is the half of the 'standard' life of the drum, developer or transfer belt. There is a big difference between running 100 jobs of one page and 1 job of 100 pages, just thing of stabilization needed for each job.
