Bizhub 210 crackling
  • MihaiGSM
    Hy all!
    The copier has 160.000 copies on counter. A few days ago, it started to make crackling noise from imaging unit. I found the drum charged with developer at one side. I cleaned it, it worked about one day, but today started again to make crackling noise. The drum was again dirty at the same side. What must I check? The seals on the magnetic roller are good. Thanks in advance!
  • ni311
    • May 2008
    • 658
    Take it out and try to rotate the drum with your hands, you should hear the noise. Most likely one gear is broken.
    • mo0651
      • 1054
      It could be a partially torn transferbelt.
      • minimerlin
        • 851
        On a BH210? I think you may be getting mixed with the color machines.
        Please do not PM me without asking first.
        • mo0651
          • 1054
          OOPS! Sorry I was thinking of different post. Any Way. Open the top of the imaging unit and look at the waste toner auger. sometimes mylar and little gears get loose in there.
