white shadow when printing with Minolta C250
  • robizhub
    • Sep 2008
    • 36
    From time to time in the last 4 years I get a text white shadow at printing.
    The shadow are always present whean apair, doesn't matter how many copies are make.
    After this I change the belt and the image units!
    I put in atachment a image.
    Please help me to solve this problem!
  • minimerlin
    • 851
    Have you changed the transfer roller?
    Please do not PM me without asking first.
    • robizhub
      • Sep 2008
      • 36
      Transfer roller was not change!
      • minimerlin
        • 851
        May be worth changing it!
        • robizhub
          • Sep 2008
          • 36
          Transfer roller was change!
          Nothing new the same print!
          • emujo
            • Jun 2009
            • 3009
            post the file, I'de like to print it to one of my color KMs. That would eliminate a machine problem and indicate something corrupt in the file itself. Emujo
            • robizhub
              • Sep 2008
              • 36
              OK here is the PDF!
              • BIG PAPA
                Da Boss
                • 234
                What type of paper stock are you using? You have changed IU's, belt, and trans roller, what is the life count on the fuser?
                sigpic
                • robizhub
                  • Sep 2008
                  • 36
                  The fuser was recently reseted!
                  The paper are 130g/mp and wery good quality.
                  • emujo
                    • Jun 2009
                    • 3009
                    I printed your image on a C451, no problems, so we can eliminate at least one aspect. You mention the fuser was recently "reseted" does this mean your re-fused it or is it a new fuser? Emujo
                    • robizhub
                      • Sep 2008
                      • 36
                      Just refused! It's a old one who needed reset with 0.08mA fuse!
                      But if I put the machine in forced stop (by example open the front door during printing) and accidentaly the paper stoped before the fuser theat shadow are already there on the paper.
                      So I make the conclusion: not the fuser!
                      Thanks for your effort "emujo"!
                      • emujo
                        • Jun 2009
                        • 3009
                        I would suggest a data clear followed by the image adjustments once more. Make sure you save any pertinent data (network info, mail boxes, scan templates etc) before doing the data clear. I might also recommend a firmware reload/update prior to the data clear to eliminate some type of corruption. From what I can see by your uploaded image, it looks like this is something the MFP is laying down on purpose. If it was "ghosting" I would think the latent images would be a little less clear, and you would see all of the original image as background, not just 2 lines of lettering. After the data clear you will need to re-install the HDD and format, re-install any fax options (if installed). Emujo
                        • fishleg
                          • Mar 2009
                          • 426
                          Those prints are A4R I presume. Vertically they line up and the only thing that is that long would be the belt to create that sort of mirrored image. With the belt changed I'd go for memory corrupt stick does all sorts of latent image artifacts usually squares but can do what you have showed in that picture.
                          Have you tried prints on A4 just to see what the outcome is be interesting to see what the mirror image looks like the other way round would tell you its the belt if the white latent image moves round if it stays the same direction then its definitely a memory issue.
                          Another stupid thing you could try the other drivers postscript pcl etc just to see the outcome if you don't get it on copies I'd test that first before you start ripping off boards. Try print as image in adobe pdf aswell just to see if it changes.
                          Hope thats of some help,
                          Fishy
                          • Srewzy
                            looks like a charge remains on a drum of KIU for me.
                            Poor drum earth contact? Try to print test pages from service mode maybe it will be easier to find out a problem...
