Counter
  • alfpanasonic
    • Jan 2007
    • 73
    Counter
    who knows how to make the digital counter goes itself to zero?
  • AusiTech
    can't do it champ!! well not in australia anyway. It's illegal.
    • Bizhub
      • 147
      What type of machine is it ???
      • alfpanasonic
        • Jan 2007
        • 73
        bizhub c250
        bizhub c250
        • nightshade
          Chromographic Supremesist
          • 158
          Why would you want to do that?
          • alfpanasonic
            • Jan 2007
            • 73
            I have a copier new in demonstration and the client had made 6000 copy
            • skirt_chaser
              Typical
              Typical, you demo a machine for somebody and they run the bag off of it.
              Then, to top it off, they don't buy it.
              • cboucher
                • Jul 2025
                Be careful with that, you could end up screwing up the consumable counts. We tried it once with a Kyocera KM-C1530 (same as Minolta, don't remember exact model). The boss thought the machine had been reset because it had a low meter, but looked old and worn. So, I found a jumper on the main board that reset the electronic meter. Unfortunately, it caused all the metered consumables (fuser unit, transfer unit, image units, etc) to reach end of life (electronically). It cost over $1,000 to satisfy the boss's curiosity.
                • knightfall
                  • Jul 2006
                  • 633
                  its basically illegal in all of the civilized world.
                  Get your facts first, and then you can distort them as much as you please.
                  • T6895
                    • Jan 2007
                    • 33
                    You can't do it! I know why you want to do it but, you can get into big trouble doing this.
                    • alfpanasonic
                      • Jan 2007
                      • 73
                      counter
                      the device sharpens the mind and the count goes to zero
                        • 23003
                        Ethics? Anyone?...
                        How about the fact that it is unethical?!?! Is there no honesty left in this field? Every salesman wants his machine to have 000000 on the counter. Well tough shit! The copies are run, Live with it!
                        • alfpanasonic
                          • Jan 2007
                          • 73
                          counter
                          I had a dream and the honesty remains.
                          The machine is in personal use
                          • kesserling
                            if you want to reset your electronic counter you can do this on C 250/252
                            but before i give you the way did you know how to upgrade your copyer
                            have you all the software by ex cygwin or something like this
                            • mitchl
                              • Apr 2007
                              • 501
                              He should use the amazing firmware imaging toolkit for loading the card for this beast which I have come to find out will work for the older models also and its much easier to use than the Cygwin nightmare!
                              But to answer the original thread question yes you can zero out the electronic counters and quite simply. Its all in the field service manual and its not hard to find so I suggest you start reading as I have a problem clicking meters in a southern direction.............. any of you guys remember the refurb copier frenzy of the mid to late 90's? Dealers would do a thorough PM in their shop click the meters back to 0 and put a refurb sticker on the back of the machine stating that the meter may not reflect the true copy count........... what a crock! I also remember being able to jump 2 points on a old Sharp like the 8100/8260/8200 and you could program the electronic meter to what ever you want, gotta love it!
