C451 jamming half fold in fuser
    • 30153
    got a C451 that half folds paper into the fuser with complete image on paper
  • Spidula
    Konica Minolta Technician
    • 83
    Congratulations
    • Spidula
      • 83
      Sorry...just kidding
      What Jam codes are you getting with it. Is it doing Duplex or single sided. Is the image fused on the paper or does it not get through the fuser at all?
      Cheers
      Spid
      • lucky13
        • May 2008
        • 125
        i have had this a meny of times 1st check the 5 pick off fingers on the front of transfer belt unit if any one finger is flipped in it catches the paper,then replace 2nd image transfer roller, then check the sync roller cleaning unit check the thin metal ground tab near the release tab for that unit clean off the built up grease and make sure there is no gap between the metal tab and brass bushing . bend tab if you have to. good luck
          • 30153
          250,000 copies on it
          where is the sync roller cleaning unit?
          • lucky13
            • May 2008
            • 125
            here you go
            • Spidula
              • 83
              Yeh. I've had those claws flip back.
              Its worth giving the registration roller (sync roller) a clean too. Use WD40 and a clean cloth or, if you have it, some rubber cleaner. Rub it till the roller is dry and has a better grip. Hope this helps.
              Spid
