hans give you the best solution with image example. If you don't want to use HDD you can disable the HDD in tech rep mode.
Bizhub 350 won't go to ready after HD installed
Quickest solution is to move the power supply too. Or if you don't want to use the hdd, simply remove it, goto tech rep mode and disable the hdd (via system input again)..
Regards.
A.Comment
Total clear is under initial mode. Remove compact flash cover, press warm restart button. When dot appears on left side of screen press 3. Enter service code,00000000. Select total clear. After exiting, cycle power.Comment
how long are you waiting when you power up the machine?? Sometimes it can take between 5-7 minutes for the machine to respond. I just installed one yesterday, and it once you turn it on in system input and than cycle the machine it will do this.....
usually sits at km logo screen for 5mins and then a few more minutes at the basic copy screen(when you touch a button at the basic screen nothing will respond)Everyone has the right to be stupid. Some people just abuse this privelage more than others
I can't get into tech rep mode. I can't even get to the basic copy screen. It seems to be in some sort of loop.Comment
I can get into initial mode - I'll give that a try. Thanks!Comment
Which I would happily do - if I could get into tech rep mode. It never completely boots up. It makes it as far as the Konica Minolta logo screen, then starts the process over.Comment
usually sits at km logo screen for 5mins and then a few more minutes at the basic copy screen(when you touch a button at the basic screen nothing will respond)Comment
Your machine is prolly looking for the hard drive, thats why it constantly reboots. It will more than likely work if you have the HD installed....with the power supply of course......Everyone has the right to be stupid. Some people just abuse this privelage more than others
Makes sense. Unfortunately, I don't have the power supply right now, although I'm going to try to find one.Comment
Hans“Sent from my Intel 80286 using MS-DOS 2.0”
Thanks for the suggestion. I prefer not to use fixes like that (using some other sort of power supply) if I can avoid it, but at least it is an option.Comment
