Konica 7145(ip-432)
  • dmw
    • Feb 2010
    • 17
    Konica 7145(ip-432)
    HELLO
    can we use 7145 with windows 7 as a network printer, how can i get the drivers for window7.
  • RRodgers
    • Jun 2009
    • 1947
    Not sure if there are any window's 7 drivers for it. Vista drivers "might" work. If ya just wanna print you can use a generic PCL driver. Course you won't be able to duplex or fold or staple and all that fun jazz.
    • copytechman
      • Nov 2008
      • 949
      Of course it depends (kinda) on what flavor of windows 7 (32 or 64 bit) but you can use xp drivers if vista ones arent available. I've done it.. Even with the older 7022 series it works where theres only xp drivers available.
      Regards!
      A.
      • newbie
        • 62
        If vista drivers are availble use them, Make sure you choose the right one, 32bit or 64bit. I do it all the time. They wont produce a windows 7 driver for that machine because its and older model. But if vista drivers arnt avalible use XP drivers. It has worked for me in the past.
