code error "D251" (C300)
  • connecticcut
    • Feb 2010
    • 53
    i have this error.What is it ? NVRAM?
  • Hansoon
    • Sep 2007
    • 3381
    There's no C300 in this machine. There is C1300 which relates to a Polygon Motor malfunction.
    • connecticcut
      • Feb 2010
      • 53
      thanks but the machine is C300 konicaminolta;i have this error =D251
      • B0265
        • Jan 2007
        • 718
        JPEG board (Scan Accelerator Kit) is not mounted when the JPEG board mounting is set ON at Service Mode.
        • newbie
          • 62
          That will do it, We only sold 3 of these and only have 1 still out. I had one take a huge dump on me out of the blue with only 18k on the clock. Personally I'm not a huge fan. I prefer the c252 or the c352 over the c300 any day, but thats only because the bad luck Ive had with them. If that doesn't fix your error post it up I can give you a few other things that Ive seen cause this. But 99.9 percent of the time going into service mode and turning it on (if its off) will fix it. Or even if its set to on just turn it off, reboot and turn it back on. sometimes it will go away. If all else fails trouble reset that Hoe.
          By the way, I have seen this error come up when people change option board settings and once when someone did a initialization on one and all the settings got tweaked. Let me know if you dont get it fixed man.
          • connecticcut
            • Feb 2010
            • 53
            thanks for yours informations
            i have to reset many times the code ,but it go back immediately...
            • deep
              • Jun 2008
              • 208
              Try Removing the JPEG Board and switch the setting to OFF.
              Kenny
              • connecticcut
                • Feb 2010
                • 53
                yes ,it's the JPEG board...thanks
