Konica Minolta Machine Trouble C0070 code
  • Facehunter
    • Jun 2025
    [Error Code] Konica Minolta Machine Trouble C0070 code
    We are IT personnel working on a newly acquired Konica Minolta Bizhub 163. We have followed the installation instructions carefully and the printer was working for a while before it gave out the machine trouble code C0070. Any idea on what could have gone wrong? How can we solve this problem hope you can help us on this. Thanks in advance.
  • emujo
    • Jun 2009
    • 3009
    there is no listing of a konicaminolta bixhub 163. Double check you info and re-post. Older Minolta products with a C0070 error code were toner related. Emujo
    • Hansoon
      • Sep 2007
      • 3374
      In Europe there is a Bizhub 163. Looks like the Di-183 family.
      Tonerbottle not sitting right. Remove tonerbottle carefully, switch on copier without bottle and wait several minutes until the machine comes to rest. (This to allow the mechanism, which drives the bottle, to come back in its startposition). Than reinsert the bottle but check before if the notches on it are damaged or deformed.
      Hans
      • Facehunter
        Thanks for your reply. The info is correct its a Bizhub 163. I found one similar post for a Bizhub 162 and hope that this will solve the problem. I've emailed it already to my friend in our site to try.
        • Facehunter
          Thank you Hans also for your reply I hope that it's just a toner bottle problem and no more. I've sent your reply also to my friend to try also.
          • aleksander
            • 378
            check the toner bottle home position sensor.
            • ineo+6501
              • Mar 2010
              • 262
              From the 163 service manual:
              C0070
              Toner replenishing motor
              malfunction
              • The toner bottle home position sensor (PS6) outputs a
              HIGH signal for a continuous 3.5-sec. period while the
              toner bottle is turning.
              LOW signal for a continuous 2-sec. period while the toner
              bottle is turning.
              • Spidula
                Konica Minolta Technician
                • 83
                http://www.copytechnet.com/forums/ko...er-bottle.html
                • eg101
                  • Jan 2005
                  • 131
                  Check the developer drive. I had a 183 recently that broke the drive gear on the rear of the developer unit. It kept trying to add toner but no drive into the mixing chamber even, a BIG mess.
