Anyone know what's a F-32-2 on a konica 7020. Thanks in advence!!!
30 codes should be fuser.
try to check the fan motor of the fuser unit if working or not
An error for FIXFAN1_EM signal is detected when 2 seconds have passed since FM8 (main unit cooling/2) has turne ON. The error does not clear after 2 seconds from the OFF/ON operation.
estimated abnormal parts:
FM8 (main cooling/2)
prcb (printer control board)
(F34-1, F34-2, F34-3, F34-4, F35-1, F35-2, F36-1, and F36-2) are connected error from the fixing unit assembly.
