minolta di 470 doc feeder not recognizing sizes
+ More Options
Posts
  • brent
    • Nov 2008
    • 1208
    off the glass the machine will detect letter and legal. off the df it will feed and then stop and say (matching paper size not available) at least I think that is what it said. if you at that point manually select a tray then it will be fine. I have unplugged and plugged in the df. I have initialized the machine. and also have checked the length sensors in the tech rep mode. I may have to replace the pwb a in the df. what are some thoughts on this? thanks
    brent
  • rocky246
    • Feb 2007
    • 91
    Does the machine say what size original is in the feeder when you place it on the tray? I had a machine that detected originals as 11x17, no matter what size the original was. The problem ended up being the lights above the machine! I moved the machine a few feet and never had the problem again.
