c500 banding
  • random
    c500 banding
    I have a machine banding. Pitch is too narrow for a drum or transfer roller doesn't go all the way across the page. Seems to be on all colors, black looks ok. I have changed t/belt assy, drums, dev tanks, HV removed and cleaned drum shafts. Out of ideas now.
    thx
  • Bizhub
    • 147
    Have you stopped the print 1/2 way through and checked the image on the transfer belt?
    I have found that the transfer belt cleaning unit when blocked causes this effect, so it may need stripping and cleaning out.
    Regards
    • Rudi
      • Jun 2007
      • 251
      just a simple question i have never worked on a c 500 before , did they take technology back to the cf900 , 1 drum 4 units ?
      Just curious.
      • JSC
        Gimp
        • Dec 2006
        • 618
        Just curious.
        No, its 4 Drums, 4 Dev units, and 1 Transfer belt unit..........
        The gene pool could use a little chlorine.
        • JSC
          Gimp
          • Dec 2006
          • 618
          thx
          You could try and exchange the carona assys with different colours, run of test prints in cmyk at about 120 to see if is on more than 1 colour, do what Bizhub says to check/rule out transfer assy and fsr unit
          • random
            I had but a new t/f belt in but blindly used the same cleaning unit so you might be on to a winner!
            I will let you know.
            • AusiTech
              Maybe check lower fuser roller, could be damaged or marked.
              How many copies has it done?
              • TonerMonkey
                • Jun 2005
                • 71
                Suggestion for c500 banding problem
                Known problem with these machines, make sure EVERY metal roller and especially the plate with the ridges on it in the transfer belt unit is spotlessly clean, I'm 99 % certain this will cure your problem.
