Konica 8031 C1220 and 'clunking' sound
  • edrummie
    • Jul 2025
    [Error Code] Konica 8031 C1220 and 'clunking' sound
    I've had this 8031 for 2years. I've replaced a number of Toners and Imaging units, as well as the Fuser and Transfer Roller - all without incedent. I tracked down the Tech password and reset the counters for the Ozone Filter and the Transfer roller (to clear the messages off the display).
    However, I recently replace a Cyan Imaging Unit last week and it printed a test page and 20-30 pages fine until it started to misplace color. It has also started to 'grind' when the motor is getting started, like a gear is mis-stepping or slipping 'clunk - clunk - clunk' in the back. On it's own - this does not create an error at startup, but if I try to print or copy - it happens again, just as the printer is getting ready to print and I get the C1220 code.
    8031 with Duplex and Finisher, 3Xe Fiery Driver. Room temperature is a bit high at 23C/75F.
    Image Transfer Belt is just over half
    Thanks, E.
  • RRodgers
    • Jun 2009
    • 1947
    Thanks, E.
    Put the old Cyan IU back in and see if still makes the noise.
    Waste toner boxes would get noisey as well.
    • edrummie
      RE-use old (not available)
      I can't try the old Image Unit as it was reported as 'end of life' and since the copier worked with the new unit, I sent the old one off to recyling.
