i cheked CD ,FD &Restart timing. It was ok .everthing i set as service mannual.
for examble if print a job in 13x19 size , 250gsm , bypass or LU,Sigle side .
if i measure non printable area in all the four sides,
right side & left side measurement is ok (ex:7mm on both sides)
leading edge &trailing edge measurement is not ok (ex:lead-7mm, trailing -9mm)
That means image is not centering on front side.
because of this back side image also not center.
papersize is exact 13x19 only.
the allowable error in feed timeing on that model is 2mm per side on 11x17, thus you could see up to 4+ mm of feed timeing error on a 2 sided 13x19 print.
