Question if you run a large size doc is the error consistant through the entire doc or does it vary within the doc?
image registration problem in km 6501
Maybe OP was referring to a bit of Magenta mis-registration , I tend to see this on heavy stock on small white text on a solid background. It might not show on 100gsm. If you look at the text with a loup you see the magenta knocked out by about 1/2 pixel and if you have 7 or 8 point font it looks like its filling-in with a red tinge. Especially around the 300-360mm area. Transfer belt/Fuser shock scenario.
Really its a Limitation of the machine.Comment
Laughing......Comment
