bizhub c252
  • hussain
    • 28
    [Misc] bizhub c252
    Dear my BROTHERS,
    bizhub c252 I am facing a new problem. Screen alignment is lost, I tried to adjust by selecting the screen adjustment, but when I point the 4 adjustment dots it isn't select. But later I noticed the whole screen is shifted approximately 1 inch horizontally to left side. If I have to select the screen adjustment dot I have to select it 1 inch away from each dot.
    Any of you have faced this type of problem ?
    Please share your opinion,suggestion or remedy to this matter.
    Thank you
  • knpgazem
    • Jul 2008
    • 35
    my friend, you have, what we call in the industry, a "broken LCD screen".
    slow and tiresome process: repeatedly 'adjust' the screen until it eventually works.
    quick and easy process: replace the fault unit and be on your merry way.
    • Stirton.M
      All things Konica Minolta
      • Oct 2009
      • 1804
      Originally posted by knpgazem
      my friend, quick and easy process: replace the fault unit and be on your merry way.
      Yup...what he said.
      "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
      ---Groucho Marx
      Please do not PM me for questions related to Konica Minolta hardware.
      I will not answer requests or questions there.
      Please ask in the KM forum for the benefit of others to see the question and give their input.
      • hussain
        • 28
        You mean it's not possible to adjust
        • Albonline
          • Sep 2008
          • 1144
          try taking it apart and cleaning the edges of the touchsheet, also examine the sheet for dents and divits , if its damaged you will have to replace it .
          • Stirton.M
            • Oct 2009
            • 1804
            The adjustment you have access to in the accesability screen is the only way to do it. If you cannot get the machine to accept and keep the settings, in all likelyhood there is a problem with the unit.
            Cleaning might work. And it might not. Damage to the touch pad would certainly require it to be replaced. Generally, these are not serviceable beyond the adjustment, and perhaps replacing the keypad or screen with a "used" item from a writeoff machine.
            ---Groucho Marx
