F42-04 on a Konica 7075
  • mrwho
    Major Asshole!
    • 4299
    Hello guys and girls.
    I've got a 7075 machine showing up with a SC42-04 code. The obvious culprits (related cooling fan, DCPS2 and driving board) were exchanged with another machine, all without success.
    Some curiosities:
    - The error is not persistent - the machine could be firing up the code on one day and then work fine the next one, giving back the code the day after that.
    - I can make the error go away if I turn on the machine without the drum unit and then, if I place the drum back on the machine without turning it off, there's a good chance the machine will work fine for a while or even the rest of the day.
    - I've tried disconnecting the finisher and pulling out all the trays to check if there could be any binding that could cause it.
    - I've also checked the drum bed, developer unit, cleaning unit and vertical conveyance for any bindings.
    Any tips?
    Thanks!
    Mascan42
    Ibid
  • Albonline
    • Sep 2008
    • 1148
    I seem to remember somthing about drum heater contact brushes causeing weird trouble codes on that model
