C6501
  • gamalmehdar
    • Mar 2008
    • 55
    C6501
    the machine give the error C1541 .
    i disconnect all the finishers but still the error?
    how can reset this error???
    thanks for all
  • sbillis
    • Nov 2008
    • 95
    what the error tells you do check?
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
      Paul@justmanuals.com
      • Stirton.M
        All things Konica Minolta
        • Oct 2009
        • 1804
        thanks for all
        Ignore the manuals4you spammer, his manuals are out of date. You should be able to download them via Konica Minolta Tech Support.
        The error relates to the perfect binder option of the finisher. If you are getting this error without the finisher connected, then the printer control board (PRCB) might be at fault and it is there you should look further, either by checking the connectors on the board and reseating all of them or replace the board itself if all else fails.
        C-1541
        After the warm-up is started, temperature detected by the glue tank temperature sensor / Lw (TH4) has not risen to a prescribed level within a specified time period.
        Places to check.
        AC drive board (ACDB)
        Glue tank heater (H1)
        Glue apply roller heater (H2)
        PB control board (PBCB)
        PB drive board (PBDB)
        Glue apply roller motor (M32)
        Glue tank temperature sensor /Lw (TH4)
        Software switch 7-7 can be switched from 0 to 1 to disable the perfect bind feature as a troubleshooting measure.
        "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
        ---Groucho Marx
        Please do not PM me for questions related to Konica Minolta hardware.
        I will not answer requests or questions there.
        Please ask in the KM forum for the benefit of others to see the question and give their input.
        • gamalmehdar
          • Mar 2008
          • 55
          thanks for all
          yes that is the software switch its the problem
          now its ok
