Konica Minolta Bizhub C250
  • darrengal8
    • Jul 2025
    [Error Code] Konica Minolta Bizhub C250
    We have been getting this code cfb55/58 every so often, has any body got any any thoughts on this code.
  • JSC
    Gimp
    • Dec 2006
    • 618
    CFB55 DMA_D 0 error interruption Error concerning
    Data transmission
    Bus or hardware
    (Engine output system)
    • MFP Control Board (PWBMFP)/
    Engine
    CFB58 DMA_D 3 error interruption
    Error concerning
    Data transmission
    Bus or hardware
    (inside the Board)
    I'd try new RAM 1st.
    The gene pool could use a little chlorine.
    • oem
      I found this:
      The above trouble code might occur when electrical noise generated at the transfer belt unit section that influence to the electrical control.
      [Solution]
      The grounding spring is newly fit onto the frame of the transfer belt unit. See the attached file.
