banding c6500
  • Haroldbfix
    • 212
    #16
    Hey Random, I received the Color registrtation unit. I will perform all the gamma adjustments afterwards. Is there anything else that I should know? Calibration of the Fiery etc...?
    • DadO
      • Dec 2007
      • 404
      #17
      I saw this on C252 and its developer.Machine, literal eat all developer since there was missing toner on developer(god know why) as in developer chamber
      Check the level of developer
      • bowser
        • 25
        #18
        banding
        i have also seen this problem and
        the gear drive was damaged from shipping on the back of the dev in the magroller
        (only if it is wider gap and more noticeable on the back side)
        yours looks far worse though
        • bowser
          • 25
          #19
          food for thought
          just a guess after some research on this banding problem i beleave it is bias in the devunit. i think the dc bias hsa been lost in the one colour
          unit (see pdf attachment). you can confirm this by adjusting developer AC frequency in service mode-process adjustment-process fine adjustment.
          increase the frequency and the banding should move from 2 inches to 2+ .
          play with these adjustments and see if something under fine adjustments may solve your problem. possibly HV1 may need to be replaced or check your contacts.
          i do not have a machine doing this at this time to confirm.
          please let me know if anyone has a opinion on this thought.
          random hope this helps also feel your pain
          • random
            #20
            This does make some effect on the banding but unfortunately you get extremely grainy highlight areas.
            • jon333
              #21
              banding c6500
              Hi Random
              with the banding issues, had very simular fault with all individual colors at half tone found that replacing the complete transfer unit fixed the problem. please let me know how you went.
              • beano
                • 54
                #22
                try swapping charge units to see if problem follows
