banding c6500
  • random
    banding c6500
    The attached image is a slight exaggeration of what I am getting but I guess you will get the picture. Yellow banding - anyone had similar?
  • AusiTech
    Hi Random
    Does this occur on full color and/or individual ones?
    Might be dev sleeve or waste toner blocking up on t/belt unit.
    I'm trying to think what 2" diameters are in the machine...
    What about 2nd transfer roller?
    There are small belts that drive the waste toner on the drum units at the rear wall of the machine, I've had them strip teeth, might cause banding. Bit bigger than 2" though.
    Is it getting worse?
    • random
      It is is only yellow as blue, magenta, cyan black are fine. Have put in new tank & belt, hasn't hit it's first kit yet so one would hope all the other stuff is fine.
      • AusiTech
        Might be a faulty drum, you could swap it with another color to check.
        The laser units are known to play up in early models, you could swap that too. make sure you set the values right when changing.
        cheers
        • Haroldbfix
          • 212
          Reply
          I have seen this problem as well. Unfortuately there is no known fix. I have address this issue with SSD and have sent samples as well. This has been escalated to Japan as far as I know. There are a number of C6500 that are doing this.
          This bands will show up usually when half tone are used.
          • random
            The fix for this is a third type of color registration assembly. The toner density is insufficient in the developer tank and this banding is caused by the developer tank not having enough toner on the mag roll. Request the latest version and fit it, make sure you do all the gamma sensor calibrations and setups.
            • Haroldbfix
              • 212
              Where can this third type color registration be found? No one else seems to know about this?
              • random
                Part number is A03UR79800 good luck!
                • Haroldbfix
                  • 212
                  Ill order a couple and install them on a couple of notorious machines. Thanks!!!
                  • random
                    The part is not specifically for that fault but we have found it solves this problem. Make sure you do gamma sensor calibration.
                    • mikeena
                      field service supervisor
                      • Mar 2007
                      • 216
                      if this dont work what i would try to do is switch the developing units leaving the front doors open so it dont dump toner in and leave the yellow developing unit out. ex. switch yellow and black positions jig the door and keep yellow on the outside. see if the black starts to transfer over if not try replacing the unit. i have bandiing issues only on this machine twice each time it was the developing unit
                      • Haroldbfix
                        • 212
                        Weve tried 4 dev units, write units, image process board, Printer control board, transfer unit complete, re PM machine twice (drums dev coronas, etc...), and replace everything else that moves still same results. Im hoping this new part gamma unit solves this nightmare. Ive talk to KMBS Instructors, DSM and any and everybody else out there including tech support. Konica aknowleged the sameples that were sent however has not produced a resolution.
                        • random
                          I feel your pain, we did the same!
                          • Operator Error
                            Banding
                            Did you try the flexcapacitor HAHA just kidding bitches. I've had this issue before and I corrected it with swapping out the coronas with fresh ones.
                            • random
                              Swapping coronas? didn't think of that. (please sense sarcasm)
